Crank shaft bolt broke off - 2004 accord
I have a 2004 Accord EX 52K and have followed all service requirements. I had car serviced 3 months ago and yesterday the bolt that I think controls the serpentine belt snapped off.
Did my dealer tighten the belt too much. They mentioned I don't drive enough to keep it lubricated but this seems absurd. |
Which bolt broke exactly?
Was it the one that holds in the tensioner, or the one on the crankshaft? |
The serpentine belt tension on the 4 cylinder is self adjusting controlled by a spring. To service the vehicle there is a bolt you turn against spring tension to remove belt and do the same to install then just release. You title for your post mentions Crank bolt?
1 Attachment(s)
I attached a pic. Is it the bolt that is circled in green or red?
