Cruise Control
Hey its a 94 4dr accord, the cruise control worked b4 and just one day it stopped working. I checked all the fuses and none of them were blown. Any suggestions?
RE: Cruise Control
Actuator went out? Switch contacts worn out? Kind of hard to test since you can only activate cruise above 30 mph.
RE: Cruise Control
yeah, sux. well the lights and everything come up saying its on but the motor or whatever it is, dosent hold down the petal.
RE: Cruise Control
Suggest you download the 94-97 Accord manual (see Online Manual link under DIY). There are several tests on the actuator which may be your problem since set light engages indicating column switch is functioning. It could be lack of vacuum supply or faulty actuator.
good luck |
