-   -   Cruise Control Problem (https://www.hondaaccordforum.com/forum/general-tech-help-7/cruise-control-problem-10842/)
waz2k5 Jul 9, 2007 06:33 AM
I recently had my transmission fluid and timing belt changed as my 96K maintenance came up.
Driving home from the dealer I decided to use the cruise control, but it wouldnt work. It had previously worked the day before.
PROBLEM: I can press the CRUISE button and the light turns ON in the console and if I press the SET button that also turns on in the console, but when I release the gas pedal the car slows down and it appears that the cruise is not engaged.
My question is whether anyone knows if I should check anything before going to the dealership or whether it could be something they did when doing my maintenance. Thanks.
EDIT: I drive a 2003 4-cylinder.
Chiovnidca Jul 9, 2007 05:38 PM
RE: Cruise Control Problem
Maybe they left the vacuum line or wiring off the cruise control actuator?
hondadude Jul 9, 2007 06:37 PM
You should head back to the dealer and ask them to plug the cruise unit into the harness. [sm=exactly.gif]
