Cruise Control Problem
1 Attachment(s)
I'm trying to track down a cruise control issue. The cable is adjusted correctly, the main light on the dash comes on but the one in the cluster doesn't, all vacuum lines are good, fuse is good. I think it's the servo itself but my question is if you pull on the cable from the servo body, should the entire cable pull from the body of the servo? I attached a picture and circled what i'm talking about in red.
yes my cable pulls out like that as well.
Thanks I appreciate it. Any ideas as to how to fix or test further?
Have you downloaded the manual?
I think there is a testing procedure there. |
I havent downloaded the manual. Where can I find it?
Open the common diy thread on top of the gen tech help forum. There is a link to online shop manuals. The honda-tech site has a 94 shop manual that you will help you out.
