Cylinder Position sensor
Old Sep 19, 2007 | 05:32 PM
wiz929
Default Cylinder Position sensor
Hey how you guys doing?
Well my girlfriend check engine light came on and i took it to autozone turns out its the Cylinder Position sensor connection is lose. By any chance does anyone know where it is located on a 2000 Honda accord 4 cyl vtec?
Old Sep 20, 2007 | 07:21 AM
BlkCurrantKord's Avatar
Default RE: Cylinder Position sensor
Its in the distributor and you may end up replacing the whole distributor cuz I don't think its something you can just remove.
Old Sep 20, 2007 | 11:54 AM
Following is suggested repair.
Disconnect the distributor connector, and check the sensor for resistance. You will need a manual to know which pins to check and for the resistance spec for your vehicle, but it's usually < 1000 ohms for a functional unit. It could be a loose connection or damaged wiring, but a bad sensor is more likely. No replacement sensor is available.
If sensor is defective, buy a new ($$$), aftermarket ($$)or used ($)replacement distributor and replace unit. Check ebay for aftermarket and used units. Check car-part.com for used units near your location.
Old Sep 20, 2007 | 12:16 PM
I was gonna check to make sure, but I think in 2000 that sensor is located down at the crank pulley, combined with the CKF sensor.
If you're checking for loose connections, it won't hurt to check both places. Look for a wire coming up along the back side of the lower timing cover, there's probably a plug located somewhere around the brake master cylinder.
Old Sep 20, 2007 | 01:46 PM
00AccordLX5spd's Avatar
Registered User
I think JimBlake could be right here. i swear I remember reading something in my Haynes about that sensor being located down at the crank pulley on the 2000-2002 models. I am at work now, i'll check once i get home. I know Haynes is not Helm, but I think they even showed a picture of it.
Old Sep 20, 2007 | 03:13 PM
Ah....mine's a 98 and its in the dizzy. I went through some BS with it last summer.
Old Sep 20, 2007 | 05:48 PM
deserthonda's Avatar
it is located in the dizzy.....
try something first.. make sure all the connections are properly connected and tight, including plug wires , also, believe it or not,, chk to see if the coil shield is installed and installed properly,there is a service news about this , that if shield is missing or not in a proper position it will kick the cyp code p1381 p-1382....then clear the code and test drive it,, if code comes back, you need to chk the cyp sensor at distr,,
unplug the 4 wire connector at dizzy, ( key off ) if you look at the connector with the nipple up, you need to chk resistance ( using an ohmmeter ) between the 2 terminals farthest to the right ,, it should be between 800-1500 ohms. ,, If not, replace the distributor housing..
if it is ok,,,,, chk for continuity to ground between each terminal ( same ones ) and body ground .If there is continuity replace the distributor .
if no continuity then we have to chk at the ecu connector .
So,, do these tests and let us know ..
Old Sep 21, 2007 | 08:59 AM
Registered User
BlkCurrantKord was right from the start.
dh got on here and beat me to the punch. With better info I might add. I was going to confirm it is in the distributor and a non replaceable part. Try the tests dh posted & let us know how it goes.
JimBlake: I think it is actually the TDC sensor that is combined with the CKP sensor that you are referring to.
Old Sep 22, 2007 | 07:43 AM
Sweet...
Let me tell ya, diagnosing that thing was a PITA last year
Old Sep 23, 2007 | 11:20 AM
Yeah, it's the TDC & CKF combined down at the crank pulley. That's whatI get for trying to remember instead of looking it up.
