dash lights not working
Old Apr 27, 2008 | 05:07 PM
bbcobra
Default dash lights not working
I've been searching this subject for a couple of weeks now. I have a 99 accord ex. the dash lights and ac control lights are not working. I did the check on the dimmer found on one of the threads. It reads from 0 to around 19+ ohms. I have replaced the drivers side multiplex controller and the instrument cluster (junk yard parts). No difference. What else could cause this problem. I've also checked the fuses.
thanks
Old Apr 28, 2008 | 10:53 AM
bbcobra
Default RE: dash lights not working
hello, any help out there?
Old Apr 30, 2008 | 11:40 PM
finch13's Avatar
Sorry, I don't have any advice to offer, but try posting in the electronics section and you might get better results.
Old May 1, 2008 | 11:03 AM
bbcobra
thanks, I'll do that.
Old May 1, 2008 | 11:40 PM
deserthonda's Avatar
Ok lets see if we can fix this ...
First of all did you chk the fuses ??
Underdash driver side fuse # 9 7.5 amps
Underdash pass side fuse # 10 10 amps
If fuses are bad replace and recheck
If fuses are ok..
Rt side under dash by the kick panel , there is the taillight relay , it has 4 wires ,( 2 red/green, 1 red/yellow and 1 red/black..
with the headlite switch on, you should have power at both red/green .. ground at the red/yellow and power at the red/black
if you have power at both red/green, ground at red/yellow and no power at red/blck ,, you got a bad relay..
it you got all the proper power and ground at relay, than you got a wiring issue from relay on,,
A quick test is to give power to the red/black wire with head lite switch off ,, if dash lites wotk than you know the the wiring from relay downward is all good .. but chk the easy things first ( FUSES) ,,
Old May 2, 2008 | 10:15 AM
bbcobra
hey thanks, that's alot of help.
Old May 3, 2008 | 09:28 PM
bbcobra
ok, the fuses are good. I already checked these including the fuses under the hood. I can't seem to locate the relay though. All I can find under the dash on the right side is the connectors for the ac / heater unit. I'll keep looking. I even looked behind the kick panel, nothing there either.
thanks for the help
Old May 8, 2008 | 07:17 AM
bbcobra
can anybody point me in the right direction to find the relay. I dont see one on the passenger side. Is it near or behind the fuse box?
andrew404
Oct 17, 2020 09:43 PM
csh217
Apr 30, 2013 09:03 PM
Uberpippi
Feb 1, 2013 10:09 PM
jayy123
Nov 1, 2011 09:36 PM
AJKing
Jul 11, 2011 08:38 PM
