Dash, Turn signals, Tail lights
Hey guys just got a car and the 3 things on the title dont seem to work at all. I checked all the fuses and they are all good so could it be the head light switch?. thats about the only thing that works and the brakes. car is a 1995 accord ex 2 door. thanks in advance!
test to see if the hazard lights work - if they do not pull the hazard button out and see if it is hooked up.
Report back your findings |
Hi, thank you for your reply! The hazard lights do work all 4.
Do you have a test light?
You are going to need it for testing. Here is a great thread. Follow the steps Poorman gives for testing and report back what you find. https://www.hondaaccordforum.com/for...problem-46919/ The blinkers I am not sure on, did you test each fuse in both fuse boxes (drivers footwell and under hood) just looking at them is not good enough. |
Thanks Ill reply tomorrow, to dark out right now.
