Dashboard warning lights trouble shooting
So I have a 09 accord LX and she has been a cherry since I got her but all of a sudden the dashboard is reading that the parking brake is pulled and the VSA light is on as well as the tire pressure warning, but as far as I can tell none of those warning are actually correct. So my next thought was a fuse possibly? But I can’t seem to be able to find out which one it is to check it… any advice or help with the location of that fuse would be awesome! Thanks in advance
One fuse would not be dedicated to that brake light. You would see a host of issues if that fuse was blown.
Check the bake fluid level on the brake master cylinder. A low level can cause the e-brake light to turn on and turn on the VSA system. I'm not sure how the tire pressure factors in. |
