Denso universal oxyen sensor for accord 91
Old May 13, 2007 | 10:30 AM
Hoang_Nguyen
Default Denso universal oxyen sensor for accord 91
Hi everyone,
I just bought a Denso universal oxyen sensor that comes with 4 wires with the following wiring configuration:
Terminal 1-white, Terminal 4-black, Terminal 3- black, Terminal 5- blue
The connector on my Honda Accord 91 EX giving me Terminal A, B, C, and D. I had an old existing old NGK oxygen sensor on my car with this configuration: Terminal A-black, Terminal B-black, Terminal C-green, Terminal D-white.
Would I equate:
Denso blue wire goes with green wire of NGK ...connect to connector's terminal C...is this correct?
Denso whitewire goes with white wire of NGK ...connect to connector's terminal D...is this correct?
how about the black wires? which black (terminal 4 or 3 of Denso) would go to terminal A and terminal B of the connector?
If you have a Denso Oxygen Sensor Direct fit ...would you upload the picture that shows which colored wires go in the connector (Terminal A, B, C, D).
Thanks and appreciated,
Hoang Nguyen
Old May 13, 2007 | 10:37 AM
hondadude's Avatar
Default RE: Denso universal oxyen sensor for accord 91
You can find the heater circuit by checking resistance
Old May 13, 2007 | 10:59 AM
Hoang_Nguyen
Thanks Hondadude. Thanks for the picture but yours is good with the NGK wiring configuration. The Denso oxygen sensor the one end where the 4 wires comes out ...it has #1-white, #4-black, #3-black, #5-blue ...Would you tell me how would I equate this Denso wiring configuration with your picture?
Old May 14, 2007 | 07:40 AM
Hoang_Nguyen
Everyone,
Luckily I got a response from ebay Global-Automotive that show the wiring configuration of all universal oxygen sensor (that has 4 wires):
http://stores.ebay.com/GLOBAL-AUTOMO...G-DIAGRAM.html
Thanks everyone!
el_chalako
Jan 17, 2011 11:07 AM
HORSEPOWERJUNKIE2007
Mar 31, 2008 04:53 PM
DMN_RITE
Apr 20, 2007 03:27 AM
Brian
Apr 12, 2006 12:20 PM
saad180
Apr 2, 2006 01:39 PM
