-   -   Dexron III ATF (https://www.hondaaccordforum.com/forum/general-tech-help-7/dexron-iii-atf-63237/)
mtill58513 Apr 28, 2016 09:17 PM
Dexron III ATF
I've got a seal leaking or a bad half shaft on my 2000 v6.
It's slinging a little ATF on the driver's half shaft. I'm putting it in the shop Monday afternoon and am checking fluid level to make sure it doesn't get too bad. I have some O'Reilly ATF which is a Dexron III substitute. Can I use this stuff in my car or should I stop at a store tomorrow and get the Honda official stuff? Does it even matter? My owners manual says use the Dexron stuff just as a temporary substitute and swap all the fluid out afterward. Any help would be greatly appreciated. Thanks.
shipo Apr 28, 2016 10:09 PM
It matters; BIG TIME. Whatever you do, do NOT pollute your transmission with Dextron III.
mtill58513 Apr 28, 2016 10:24 PM
OK. Thanks for the heads up. I may just swing by the dealership tomorrow after work and get the official stuff.
