diagnose egr valve or egr solenoid
Old Sep 8, 2008 | 07:35 PM
RJLhonda
Default diagnose egr valve or egr solenoid
I have a 97 honda accord 2.2 vtec and the check engine light is on and I had the code pulled and I either have failed egr valve or theegr solenoid is bad how do I diagnose which one it is. Also I checked the lines and they are not plugged
Old Sep 8, 2008 | 08:10 PM
Default RE: diagnose egr valve or egr solenoid
What code? It could be failed EGR, blocked EGR manifold ports, or loss of vacuum to actuate the EGR.
Old Sep 8, 2008 | 09:32 PM
RJLhonda
Auto Zone pulled the code and the Definition: EGR system fault (Exhaust gas Recirculation)
Explanation: The ECM has detected too little flow on the EGR system. Probable Causes: 1 blocked passage on the EGR system,2 failed EGR valve,3 EGR solenoid faulty, The hoses connected to the EGR are not pluged so I'm down to the other possible causes I just need to know how to cheek the parts thank you
Old Sep 9, 2008 | 01:05 AM
The ports on the manifold are the likely clogged. Google t2t013.pdf and the last two pages show the steps for a 94-97 accord.
Good Luck.
NZXTInerTia
Jul 20, 2012 03:06 AM
archangel_1988
Dec 13, 2011 11:43 PM
HondaKing
Jun 13, 2010 10:06 PM
HondaKing
Jun 13, 2010 02:20 AM
appleman
Sep 27, 2007 11:44 AM
