Differential Oil
How does one check and replace the differential oil in my 92 Accord LX? What type of oil should I use synthetic, oem?
RE: Differential Oil
the differential shares with the trans. Use Honda Z-1 ATF 3 quarts per change
ORIGINAL: hondadude the differential shares with the trans. Use Honda Z-1 ATF 3 quarts per change 91....if it is AT tranny do as Dude suggested...............also input the year and model in your signature so we do not have to guess :) if it is a manual tranny use 10w30 motor oil .any brands will do ......almost 3 qts per drain and refill |
ooops my bad [sm=bustedsign.gif]
Yes it is an automatic so I guess when I drain and fill the tranny the differential is taken care of. Thanks guys this is a great forum. Deserthonda I have added a sig. to my profile so details will show on future posts.
thanks for adding the year and model on your sig, and remember to use only Honda ATF-Z1 3 qts for drain and refill
