-   -   Do I need a new starter? (https://www.hondaaccordforum.com/forum/general-tech-help-7/do-i-need-new-starter-63000/)
drdba Feb 29, 2016 03:24 PM
I have a 2003 Accord Coupe, 107K miles, new battery, and new alternator.
I am getting the "electronic buzzing" sound more often when I start my car. I realize that you need to turn the key fast, but this awful buzzing sound is getting more frequent during start ups?
Do I need to replace my starter?
holmesnmanny Mar 2, 2016 03:23 PM
If you have an aftermarket alarm it's possible the starter disable function is going bad.
redbull-1 Mar 2, 2016 03:42 PM
Some early 7th gen Accords had issues with the ignition switch or starter cut relay which will result in the buzzing noise. You can try swapping one of the same type relays in the driver's under-dash fuse relay box to see if it makes a difference.
UhOh Mar 4, 2016 12:26 AM
If you can start the car each time you turn the key the starter is working.
But what's with this needing to turn the key to start position fast?
Never heard that before. Is time delay related to the buzzing for your car?
holmesnmanny Apr 3, 2016 05:22 AM
Please update this when you find the problem. Thanks
