-   -   Dome light Problems (https://www.hondaaccordforum.com/forum/general-tech-help-7/dome-light-problems-22538/)
cjdm98 Dec 24, 2008 01:32 PM
Dome light Problems
Having a problem with my dome light and map light,i was trying to install my ebay led lights,they didn't fit correctly,so i tried to force them in there,..long story short...saw a spark,put my old bulb back in,and now my dome and map lights will not turn on,i already checked fuses,and etc..
Any suggestions?
finch13 Dec 24, 2008 02:10 PM
RE: Dome light Problems
Noob. No clue what to tell ya...
cjdm98 Dec 24, 2008 04:12 PM
Ugh..this is pissing me off.
cjdm98 Dec 29, 2008 04:41 PM
Got the dome light working now, But....The light doesnt dim out when i have it on the "door" setting..Normally it dims out then off.Now it stays on...Any Ideas?
finch13 Dec 29, 2008 09:48 PM
Your dome dims out? Mine just turns on and off with the door... I guess I fail and now you fail too.
cjdm98 Dec 29, 2008 10:01 PM
It basically turns off,but now it stays on,even when all doors all closed.[:@]:eek:
Canuckle04 Nov 29, 2011 01:26 AM
I know it's an old thread but I've had the same issue.
Doors closed but dome light stays on when in 'middle' position?
Any suggestions?
Thanks;
cutlass327 Nov 30, 2011 11:50 AM
Was this after the conversion to LED? If so, the LED doesn't draw enough power to used the stored energy in the capacitor that causes the fade-out, if they have it designed so that is dependent on the bulb. Otherwise, you may have toasted the transistor the controls the dimming.
LEDs are nice in that they are colorful and cool, but not every incandescent bulb can be replaced by them properly. LEDs don't fade/dim, they are usually on/off.
