Door Lock problem Honda Accord 2005
#21
Hurray!!! I found a newer post on how to do the programming and this one works for me:
How to Program Factory Honda Acura Remote Key Fobs: 10 Steps
saved me some bucks. So everything works great except the rear driver's side window. I will take the panel off and see if I by mistake left something unplugged and post back if I get any good results or to let anyone reading this post know how it all ended up.
Hope this thread helps someone else too.
Best Regards!!!
Best Regards!!!
#22
Somehow I missed the "newer" posts here but it sounds like you have it figured out.
With the panel off, hope you find an easy fix. If not be sure to test the motor while there. Also, haven't seen this on the newer Accords but some of the older ones had an issue where the "connector plug" in the door jam would work loose.
#23
Battery Reset worked for me
Was having the issue with the FOB not unlocking the driver door. Horn would not beep on the second key FOB click as well. Performed the battery disconnct reset and like magic the car responds to the FOB. Had already just replaced the actuator which did not fix the problem. 2005 V6 sedan.
#24
I have to come very close to my Honda Accord 2006 before it unlocks
Hello everyone,
Been having this issue for quite a while now, i have to come close to my car, driver side or inside (and press the key fob )for the car to unlock, please what could be the problem? help.
pmay805
03-16-2015 10:41 AM
HateThisHonda
09-19-2013 09:45 AM
Doublel
03-11-2013 07:57 AM
