-   -   Door locks not working help! (https://www.hondaaccordforum.com/forum/general-tech-help-7/door-locks-not-working-help-45707/)
jdarrah66 Feb 21, 2012 02:44 PM
hello all i havee a 97 accord se. My door locks are not working properly. I do have a keyless entry which doesn't seem to be programmed right. I can unlock my driver door with the remote keyless entry and by the switch on the door....however i cannot lock it along with any other door with any of their switches . any ideas???
poorman212 Feb 21, 2012 07:24 PM
Two things. Drivers door closed, if you use the drivers lock switch to lock and unlock the doors what happens.
All doors unlocked and closed, use the drivers side outer key cyl to lock the doors. What happens.
jdarrah66 Feb 21, 2012 08:33 PM
with the drivers door closed and using the driver door switch it will unlock just the driver door and nothing happens to the other three doors.
with all the doors closed and unlocked when i use the key it will only lock the drivers door.
hope this helps!
poorman212 Feb 22, 2012 06:09 PM
Ok, I'm leaning towards the keyless entry control unit....however the manul I have only covers this on the 95 wagons....so if anyone has a better one please chime in.
Do you have a volt meter. on the pass door lock actuator, when you use the drivers side switch to unlock, the pass side actuator should get 12v on the YEL/RED wire, does it? EDIT: also do the same with the pass side lock switch, sorry left that out.
