driver seat
I have a question about the driver seat, mine is an electric one and it has a little play back and forth. Is this normal or should i tighten something, if i should what ?
RE: driver seat
it's probably normal but just to be safe check and make sure all your mounting bolts are tight.... there should be 2 in front and 2 in the back that mount the seat to the car.... give it a shot and let us know what you find...
RE: driver seat
Ok, ill give it a try tomorrow
RE: driver seat
ORIGINAL: evs I have a question about the driver seat, mine is an electric one and it has a little play back and forth. Is this normal or should i tighten something, if i should what ? |
RE: driver seat
99, accord coupe...
The mounting bolts are tight.. the part that i can see moving is the whole seat but from the buttons to move the seat, upward, whats below that does not move. |
RE: driver seat
If it's not loose bolts under the seat or somewhere then I'm not sure what you can do....
RE: driver seat
the only reasonable thing i can think of is that the motor has a little play...
RE: driver seat
ORIGINAL: evs A dealership can run your vin to see if your vehicle is affected. (or you can pm me the vin and i'll check it) |
