driver side window on 2dr 99'
My window on my car won't go all the way to the top and create a seal. It's been like that for a while but now it's getting worse. When I hit the button it rolls up fine until it gets about a 1/2 inch away from the top and then it starts vibrating. I want to take off the door panel but I've never done it before. Any ideas on what might be wrong and does anyone have link to a page that shows you how to properly take the door panel off so I can see what's happening.
RE: driver side window on 2dr 99'
Here are some instructions.... you can also click search at the top and type in "door panel" and find lots of stuff.... It sounds like it's the motor or cable, or something is stuck in the track towards the top,
https://www.hondaaccordforum.com/m_26114/tm.htm and another one (for a 94 but some of it is still relavent) https://www.hondaaccordforum.com/m_16927/tm.htm |
thank you
No problem, let us know if you run into any snags or have any additional questions....
