-   -   Driver's side low beams not working (https://www.hondaaccordforum.com/forum/general-tech-help-7/drivers-side-low-beams-not-working-62850/)
simco99 Jan 28, 2016 12:36 PM
Hello. I'm hoping someone knows about this issue and can point me in the right direction.
I have a 2003 Accord EXL, V6 VTECH, 6-spd. FYI, I'm in Canada, but the car was manufactured in the US, (no running lights, and no conversion kit installed).
Last week, the d/s low beams stopped working, both highs work fine. I finally tried to replace the bulb and ran into the problem. Here's what I know...
-not a bulb issue: replaced with correct working bulb and still no low beams (l/b)
-not a fuse issue: checked fuses, all have power
-NO power to bulb socket on l/b, but power on h/b
Clearly, I need to change something in order fix the problem, but I don't know what. Any suggestions would be appreciated.
Dr. Drivability Jan 28, 2016 04:21 PM
2 Attachment(s)
You may have lost a ground, check G201 in the picture below, it's the ground for the lighting on the drivers side.
TexasHonda Jan 28, 2016 04:28 PM
4 Attachment(s)
There is a relay control module in the underhood fuse box that controls low and high beams. Circuit diagram suggests the high beam relay (part of relay control module) is likely fault. Probably have to replace the entire relay control module. See attached diagrams.
Some diagnostics necessary to confirm faulty relay control module (no voltage on high beams output wire).
redbull-1 Jan 28, 2016 09:41 PM
1. How did you verify power (+) at the fuses and the bulb socket? With a voltmeter/multi-meter?
2. With the low beam headlight switch turned on, is there power on both side of under-hood Fuse No. 1 (10A)? In addition, was the wire you checked for power (+) the Red/Yel wire?
JimBlake Jan 29, 2016 08:56 AM
At the bulb socket, measure this way:
1) Voltage from the (+) wire to a body ground somewhere other than the (-) wire.
2) Continuity (or resistance) from the (-) wire to a body ground somewhere.
That identifies which side of the circuit you need to troubleshoot.
TexasHonda Jan 29, 2016 09:24 AM
I got hi/lo beam backwards in my post, however problem assessment is unchanged. Likely a relay problem, but checks necessary to confirm.
An easy check is to check for power to fuses 1 & 6. Check small openings on top side of fuses. Both sides should be hot w/ low beam lights on. If no power, then relay control module fault is highly likely. Small chance of a fault in fuse panel itselt; weak fuse connection, corrosion, damage.
If power is present on fuses 1 & 6, then problem lies in wiring or connectors.
Dr. Drivability Jan 29, 2016 10:27 AM
2 Attachment(s)
Hey Tex, my diagram looks a bit different from yours, only one relay each for the high and low beams. Still could be the relay control module though. I'm still leaning toward a bad ground. But testing needs to confirm or deny that.
TexasHonda Jan 29, 2016 02:10 PM
Look again at wiring diagram I attached. There a separate relays for hi and lo beams, same as your diagram.
Dr. Drivability Jan 29, 2016 02:24 PM
Correct, but he only has ONE low beam inoperative. If it was the relay, both would not work.
TexasHonda Jan 29, 2016 03:35 PM
His use of plural "beams" fooled me. Not a relay then.
