Driver's Window Stuck
So few months back my windows were acting up, moved very slow but they still managed to close/open all the way. Now today, the window is stuck in the bottom position. I took the door panel off and wiggled the window, nothing. Tried using vice-grip to yonk it up, nothing. Lubed the cables and tracks, nothing. I downward pressed the window control and you can hear an "ehk" sound (simply cant go down anymore) but when I upward press it, it doesnt even make a noise, let alone move the winow up.
So after all these, I have concluded that: The control unit is fine. All other windows work The window motor is fine, because I can hear a sound when I press downward. Nothing out of track. All wires a replugged AH! any help, its going to rain hard these few nights! Thanks |
RE: Driver's Window Stuck
My problem seems a lot like the following:
https://www.hondaaccordforum.com/m_2..._1/key_/tm.htm But his problem fixed itself! I dont know if I am going to be that lucky. |
it can be a bad switch. there is an up and a down switch you know.
ORIGINAL: HondatechAV6 it can be a bad switch. there is an up and a down switch you know. It is getting really wet! lol |
ORIGINAL: patpatpat ORIGINAL: HondatechAV6 it can be a bad switch. there is an up and a down switch you know. It is getting really wet! lol how is this a test? to test it properly you need a digital multimeter or at least a test light...do you have either? |
If you remove the door panel, you can disconnect the window from the regulator/motor (2 bolts) assy and manually raise the window. A stick of correct length can be used to jam the window in up position until you repair switches or replace regulator.
Check the plastic turning block on regulator that turns the pull wire. If this plastic turning block is broken, the regulator will jam and not rise. Replacement regulator is fix. Check ebay or salvage yard for a replacement. good luck |
So the problem was the control unit. The contact plates under the switches are burned so I cleaned them and it works now. However, when I was putting my door panel back, the doors keep locking themselves. So I tried to fix that, but I accidentally closed my doors with all the windows up(ironic isnt it)!!! So now...the car is running and I am waiting for AAA to come.....
One problem after another. Cheers. |
the cheapest way out is to go to the dealer and have them cut you a cheap key(no immobilizer chip).
I do have 2 sets of keys, but I left the other back at a different house. Do you know how much a key usually runs? I thought I can just go to walmart and get it made.
I just need to get my driver side window up it will go down with the button but does nothing going up. HELP. Thanks 94 Accord with 247.000 plus runs good 32 mph on the fwy!
| All times are GMT -5. The time now is 05:01 AM. |
