Driver's Window Switch Malfunctioning
Old May 4, 2014 | 01:07 PM
R.A.D.'s Avatar
Default Driver's Window Switch Malfunctioning
If anyone has followed the posts related to this car, you know I've had numerous issues which I needed to address after buying it a couple of weeks ago. I went into it fully aware of the things that were wrong with it and took them on happily considering the SMOKIN' deal I got on it. The only one that I wasn't prepared for was the two OBD codes associated with a bad cat but it seems that situation has worked its way out - hopefully... fingers crossed!
Anyway, the last thing I have to take care of is the driver window immediately going back down once it hits the top and I've read the solution for that. The problem is, the rocker switch for that window is worn out and doesn't allow anything other than auto up and auto down which makes it impossible to have the motor re-learn its proper function.
I searched pretty well for a replacement of just that switch in the master switch panel but all I could find was the master panel which is pricey to say the least. Does anyone know if you can replace just a single switch in that panel or do I have to get the whole thing?
Thanks to everyone for their help and suggestions throughout this project. It's been fun witnessing the progress and the transformation between now and what it looked like just a couple of weeks ago.
Old May 4, 2014 | 07:47 PM
sirtwist2's Avatar
Have you checked junk yards? I recently replaced the 4dr master window switch with mirror on my 93 Accord with one from a junkyard pretty cheaply. I just did a search and found them in the northeast ranging from $25 to $50.
Old May 4, 2014 | 08:14 PM
R.A.D.'s Avatar
The problem with the yards here is the ones that allow you to pull the part yourself have extremely dated inventory - I mean they're horrible! And the ones that dissect the cars and inventory the parts charge ridiculously high prices for everything. That's why I was hoping a single switch could be replaced in the panel.
Thanks for the reply!
Steve
jza240sx
Apr 30, 2013 04:14 PM
yutaka731
Feb 12, 2011 03:41 PM
alfawilbel
Nov 21, 2009 07:34 PM
ronniebrown2323
Jul 21, 2009 12:15 PM
RuthlezzFL1P
Jul 13, 2008 08:52 PM
