-   -   Driving Woes (https://www.hondaaccordforum.com/forum/general-tech-help-7/driving-woes-42747/)
RIPauntM's Honda Sep 12, 2011 02:26 PM
Driving Woes
I have a 2003 Homda Accord...... driving just fine today, car started jumping...... won't go over 2500rpm. Had it towed home...... HELP!!! Any idea what it could be!
WheelBrokerAng Sep 12, 2011 04:15 PM
1st Let's Put You In The Right Forum...
1 Attachment(s)
Here You Are..The right forum... :) dbl click..real picture not a fake...
redbull-1 Sep 12, 2011 04:30 PM
You may have had an engine misfire and the computer kept the car in a limp-mode. Most likely the Check Engine Light was on. If you get the car scanned for trouble codes, then that could try to help narrow down what may be the cause of the problem. Without a trouble code and/or more information, there not too much we can tell you. If you do happen to be able to retrieve the trouble code(s) via someone with a OBD-II reader/scanner, then post the code and whether your Accord is 4 cylinder or 6.
