e-brake and TCS light on!
Old Sep 25, 2006 | 11:41 PM
ramman949
Default e-brake and TCS light on!
Hey all,
I got a 2003 V6 EX accord and the the ebrake and TCS light recently turned on and it wont turn off. The rear pads are 4 months old. I changed the front ones today because they looked a little low, but not even near the wear indicator. I also checked the e-brake switch under the handle to make sure that wasnt broken. And finally I checked the fluid which is right at the top of the full mark. Yet the darn light stays on. I even pulled my negitive and reset the ECU and still its on. All wheel sensors are in place. What could be causing this? I also used one of those obdII ecu readers and it said I have no codes? But someone mentioned to me that I need a different code reading tool?
The ebrake will stay light upon startup. Within 1 minute, the TCS light comes on.
ANy suggestions? Please.
Thank you,
Ram
Old Sep 26, 2006 | 04:56 AM
ramman949
Default RE: e-brake and TCS light on!
ANyone?
Old Sep 26, 2006 | 01:08 PM
hondadude's Avatar
first thing I'd check is the float switch of the brake master cylinder. check that the continuity changes when you raise the float from bottom to top.
Old Sep 26, 2006 | 03:37 PM
sir_nasty's Avatar
make sure your fluid is full too.... low fluid levels will/can make the brake light come on...
Old Sep 26, 2006 | 03:41 PM
ramman949
ORIGINAL: hondadude
My float kinda sticks. Its moves up and down with no changes to the brake light. And my 03 has an updated version of the m/c that bothered many 02 and prior models. My float looks nothing like the 02 and priors.
Old Sep 26, 2006 | 03:42 PM
ramman949
ORIGINAL: sir_nasty
Thanks for your help, but I already did check it as stated above. Thanks for trying though.
Old Sep 26, 2006 | 04:59 PM
sir_nasty's Avatar
sorry about that I totally missed that.... I believe if you take it to autozone they will scan the car for free and tell you where the signal is coming from... I know my 81 civic has the same issue but that's because the e-brake sucks and is causing it....
Old Sep 26, 2006 | 09:49 PM
deserthonda's Avatar
ORIGINAL: hondadude
totally different set up..
no more float .. the sensor now is part of the master culinder you canot replace just the sensor i have already replaced 2 mastyer cylinders on 2003 accords for the same issue ( brake lite on )
Old Sep 26, 2006 | 10:21 PM
ramman949
ah man! This better not be my M/C going out! Thanks for all your help guys. This sucks!
Old Aug 13, 2012 | 07:24 PM
will.0777's Avatar
Default TCS and Brake light.
Were you able to find the problem of the TCS and the Brake light?
I am having the same problem?
