EGR Valve disconnect
I have a 98 honda accord 4 cylinder.. the Check engine light reads an egr valve problem . Anyways..i replaced the valve with one from another honda engine..but the engine light still comes on.. Question If i disconnect the electrical plug from the valve will it damage my engine ? And if i did unplug the the cable will my check engine light come on after i reset the check engine light...
RE: EGR Valve disconnect
The CEL will come on if you unplug the EGR valve.
Search for cleaning the EGR ports, because they are most likely clogged. |
ORIGINAL: dboy the Check engine light reads an egr valve problem . |
I forgot the code.but it has something to do with the egr not flowing or something....Anyone know how much it cost to clean ports?
ORIGINAL: dboy I forgot the code.but it has something to do with the egr not flowing or something.... |
