-   -   ENGINE SEIZED UP...93 ACCORD (https://www.hondaaccordforum.com/forum/general-tech-help-7/engine-seized-up-93-accord-22952/)
will93 Jan 16, 2009 10:52 AM
My son's '93 LX, just turned 100K. Mechanic says car starved for oil, caused broken cam shaft, likely lower engine damage, so replacing cam shaft and head ONLY may be a waste of time. Suggests new engine, 40-50K Japaneese engine, $2400 for full job.
1-In your best judgement (yes without seeing car or engine) does this sound reasonable?
2-There have been NO pools of oil under car, no noticable leak. I changed oil and filter 2 weeks ago. ???? Mechanic asked if he is a "hard driver". He is 20yo if that helps. When I asked mechanic where the oil went, he had no idea. What could have happened?
EDIT TO ADD: Price above includes transmission (if that matters) and NO Blue smoke as best I can tell.
I'll hang up and listen. THanks.
live2rice Jan 16, 2009 11:02 AM
RE: ENGINE SEIZED UP...93 ACCORD
Its possible it burned all the oil, did you notice any blue smoke coming out the back? I take it the car will not crank over now.
$2400 seems steep, you can get a used engine in the united states for 3-400, and there should not be 2,000 in labor to swap and engine.
