-   -   engine size??? (https://www.hondaaccordforum.com/forum/general-tech-help-7/engine-size-21685/)
mike1053 Nov 8, 2008 08:05 PM
engine size???
Ok, I have done some b16/b18 tops and bottoms, even got a d15 in my CRX, I am at a loss here on this car, it has a SOHC engine in it with VTEC on valve cover hood has been replaced so no emmision sticker ethier, what size it is I think 2.2 but I am only aware of H22 I am not at all familar with this model or chassie code, any help be great. As I am asking for information I am looking to do some small add wheels, intake, so on I have 97 Accord EX 4 wheels disc, gold color, alloys and so on. Thanks in advance for information.
Tippman7641 Nov 8, 2008 09:12 PM
RE: engine size???
are you saying the engine code is h22? or you think its an h22?
Tippman7641 Nov 8, 2008 09:13 PM
RE: engine size???
mike1053 Nov 8, 2008 09:27 PM
RE: engine size???
I know H22 is a DOHC this is aSOHC so I am asking what size/displacement is it, I think it is a 2.2 just not sure what code or could be something else I am asking what could it be?
Tippman7641 Nov 8, 2008 09:33 PM
RE: engine size???
its 2.2 heres more info
Specifications
[ul][*]Bore × Stroke: 87.0 × 90.70mm (3.571in)[*]Displacement: 2157 cc (132 cu. in.)[*]Valve Configuration: DOHC, 16 valves, VTEC[*]Type: In-line 4 cylinder, aluminum block and head[*]Compression ratio: 10.0:1 (North America); 10.6–11.0:1 (Japan)[*]Max power: 190PS (187hp/140kW) (CD6 Accord); 200 PS (BB1/4/6 Prelude SiR's); 220 PS (Euro-R & Prelude Type-S);A7 212 bhp DIN (Type-R)(142–164 kW)[*]Max torque: 156–167 ft·lbf (207–217 Nm)[*]Redline: 7600 rpm[*]Rev Cut: 7800 rpm[*]Engine Control System: Honda Systems PGM-FI with port fuel injection[*]Valve Gear: Belt-driven dual overhead cams, 4 valves per cylinder, variable timing and lift[*]92-96 versions use closed-deck blocks with FRM liners while the 97-01 versions used open-deck blocks with FRM liners.[/ul] There is also a DOHC VTEC version of the H23A, available in the CH6 and CL2(4WD) accord (CF4 wagon) SiR in the European Markets. Specs remain largely similar to the H23A for North America, albeit differ in the introduction of VTEC mechanism and more power Specifications [ul][*]Compression ratio: 10.6:1[*]Max output: 200PS (197hp/147kW) @ 6800 rpm[*]Max torque: 220N·m (160ft·lbf) @ 5300 rpm[*]Redline: 6500 rpm[/ul]
mike1053 Nov 8, 2008 09:49 PM
RE: engine size???
Cool man thank you alot, now I can look for some stuff going to replace timing belt and others, probaly water pump, want to install a new adjustable cam gear and maybe a cam.. I am not sure on what just yet, thank you again.
finch13 Nov 9, 2008 12:16 PM
RE: engine size???
The engine code is stamped on the block near the top coolant hose that runs into the top of the radiator. If it's a 5th gen (94-97), it's either an F22B1 (VTEC), F22B2 (No VTEC), or C27 (2.7L V6)
live2rice Nov 9, 2008 01:25 PM
RE: engine size???
he said its SOHC, its stock, its a F22B1 aka 2.2l(if you havent figured out honda engine codes by now). And it is stamped right on the front of the block, right where the transmission bolts up.
