-   -   Engine starting issue...should I worry? (https://www.hondaaccordforum.com/forum/general-tech-help-7/engine-starting-issue-should-i-worry-48038/)
trilliput Jun 10, 2012 08:01 PM
Recently my car (wagon 1995) has developed this problem. If the engine is hot, it only starts after the beeps are over. You turn the key into II, wait for the beeps to pass and then crank the engine and it starts. When it is cold starts at once. I cleaned the contacts on the battery. What is this and should I worry and take it to the shop?
Thanks for your answers
redbull-1 Jun 10, 2012 08:10 PM
Sounds like an ignition switch problem. If it is, you would want to change ASAP, as the car can stall on you while driving.
There is a very good video on diagnosing and replacing the switch, I'll see if I can find it.
redbull-1 Jun 10, 2012 08:13 PM
Here the DIY video:
Honda Accord Ignition Switch Replacement - YouTube
Your symptoms are probably like this other video:
honda accord - bad ignition switch - YouTube
