Erratic Idle due to TPS?
Is it logical? when i gas it, the car jerks only in the 1k-1.5k rpm range. I've checked with a local mechanic and he said its the TPS. Unforunatly, new ones go around 500+ since they dont sell the TPS by itself, but only with the whole damn throttle body. I just want to make sure this could be a problem b4 i empty out my wallet.
PS. I've already tried replacing IAC valve, and cleaned the intake manifold. no dice. Opinions will be greatly appreciated, thanks guys. 94 Accord EX F22B1 |
RE: Erratic Idle due to TPS?
Try disconnecting the vacuum line to the egr valve and go for a drive. Does that change it?
i'll have to do it tonight after work, i'll also have to find where it is...
Tai_Boi maybe used to be chubug? from Hoston Texas.?
Welcome to the forums WheelBrokerAng [sm=americanasmiley.gif] |
| All times are GMT -5. The time now is 03:54 AM. |
