-   -   F23a1 p1399 (https://www.hondaaccordforum.com/forum/general-tech-help-7/f23a1-p1399-70227/)
Brian sabado Aug 13, 2023 12:53 AM
F23a1 p1399
I rebuild the engine and now I have the random misfire code and misfire in cyl 3 I changed the spark plugs after the first 50 miles that I drove it changed cables and distributor cap and rotor and still has the random misfire
car runs and drives fine but you can fill the engine shaking at idle and sometimes it hesitates when accelerating
no smoke coming out of the exhaust
no egr codes can someone please help me ???
PAhonda Aug 13, 2023 10:13 AM
Try swapping the #3 fuel injector with another like #4. See if the misfire code moves to cylinder 4.
Brian sabado Aug 13, 2023 05:51 PM
Even though they are new injectors
PAhonda Aug 13, 2023 06:52 PM
You can have a bad injector out of the box. This is a fairly quick and simple check. Much less complicated than doing mechanical tests specific to cylinder #3.
