ABS Light on Hear humming or buzzing
[sm=shootshoot.gif] My 97 Honda accord V6, has an abs problem. I believe that possibly the accumulator is leaking down. I have no fluid loss at all; the abs light comes on as a check light when starting the vehicle then goes out as it should. After a few minutes of either driving or sitting still, the abs light comes on, and you can hear a growling or moaning sound, which sounds to me like the accumulator recharging. The light stays on after that and never goes out until the next shut down and restart. The brakes work fine, but no abs. Is this a common problem? I have never had problems with abs on any car I ever owned outside of a cracked sensor ring or sensor. I would appreciate any info on these symptoms and possible cause/remedy.
93Accord2.2
11-07-2013 07:10 AM
