-   -   first time at the tracks..didnt do too well =/ (https://www.hondaaccordforum.com/forum/general-tech-help-7/first-time-tracks-didnt-do-too-well-%3D-31694/)
xpieceofcralpx Apr 1, 2010 03:38 PM
2002 Honda Accord Sedan 5speed
my best times was
RT: 0.95
I1: 2.64
I2: 7.142
I3: 10.830
MPH(I3): 66.999
I4: 14.046
E.T.: 16.778
MPH: 83.179
this is with a low rev launch..and when i tried different launch points from 2.5k - 3k and 3.5k .. everytime i would bog and stay in the trap zone to long and one time at a high rev i popped out of gear! this is my first time at the tracks, and i just went for fun, i know my car is NOT fast, i went with my friends who have fast cars, and just wanted to join the fun..what are your insights on my poor numbers? my car rated stock is suppose to run 16.1 so i didnt do too bad right? but i do have basic mods like intake and cat back exhaust..my friends say, its my tires/rims, i bought the car used and it came with these huge 18" kyowa racing rims..they say when i get smaller rims and better tires we should go again..what do you guys think?
dgp1961 Apr 2, 2010 06:15 AM
Huh?? :confused:
HondaAccordEX94 Apr 2, 2010 06:59 PM
Get smaller rims and tires. Try 15". Here, I found this article online. I couldn't have said this better, myself.
When factory-calibrated tires are replaced with larger tires and rims, a car's transmission will continue to run at the same speed. Larger wheels will make fewer rotations than smaller tires. This means, as the transmission continues to clock a specific speed, larger tires will actually cause the car to move more slowly than the speedometer reads. Depending on the increase in tire size, a car will usually travel about 5 to 15 percent slower. The opposite effect is realized when smaller tires are installed.
ROFLmao Apr 2, 2010 09:47 PM
That time is pretty bad. I managed to fling my autotragic Accord(VP and stock) into 16.9ish at the 1/4. It boils down to the launch to be honest. Replacing the wheels will help quite a bit as well. Larger wheels will weigh more as well as other random physics stuff that will work against you when it comes to larger wheels.
JimBlake Apr 3, 2010 10:17 PM
That's backwards... Where did you find that article?
For steady driving, larger wheels will make the car go faster - more accurate to say they'll make your speedometer read low.
Larger wheels/tires will put your engine at a lower RPM, likely results in slower times.
jbeezy53 Apr 4, 2010 02:50 PM
Agreed. Taller the tires the slower the car acclerates.
xpieceofcralpx Apr 4, 2010 10:35 PM
guess it was my rim/tire combo, thanks everyone for the feedback
