front sub-frame concerns
Hello, I'm new to the forum so I would like to thank you in advance for any advice you provide. I've had several accords and currently have 2. My 2002 ex v6 4dr at has rusted out on the pass side front sub-frame (engine cradle?) car is in good shape although it has 185 k on it. I've had it since 04 and have had only minor issues. Please take a look and let me know what's up.
2 Attachment(s)
Originally Posted by 2manycars
(Post 306341)
That looks pretty bad, but you can replace that front subframe. But before replacing it, have a shop take a real good look at everything else for structural corrosion damage. Decide whether it's worth fixing after you know the full extent of OTHER stuff that might be corroded just as badly.
everything else looks real good. just this one area bad. are others having this issue?
Can u weld? Maby u can plate it temporary till u can get the part and or time / money to fix that. It looks expensive. Just weld/ bolt acouple thick steel pieces to keep it structurely sound
Does this happen to be on the pass/right side of the car? For some reason I've see a few of the 6th gens with the pass/right side rusting out?
You could get a new one ($) or see if you can get a used one, of course inspect it real good. Then I'd be sure to add some sort of protection to the ends where the rust on yours is. |
(Post 306456)
could someone please post a front sub-frame diagram and parts list/description for 2002 accord? thanks in advance
hondaautomotiveparts.com sells all oem parts. I can't seem to find the subframe in any of the diagrams though. Maybe you will have better luck than I. Another option would be to check local junkyards
The category is "REAR BEAM - CROSS BEAM" because it's combined in the same drawing with the rear subframe. It's pricey and seems like quite a job to replace.
I probably made it sound easy to replace because I didn't originally take a good look at the parts drawings. That beam might help support the engine and the steering rack, so you have to deal with that. |
