fuel cut
Old Apr 13, 2010 | 06:12 PM
cgerlecz's Avatar
Unhappy fuel cut
i have a 1995 honda accord ex with a 4 cylinder 2.2 vtec motor and i get a fuel cut at about 5800 rpm what could be causing this?
Old Apr 13, 2010 | 06:25 PM
lilpp's Avatar
your car is a 1995 correct?
-lilpp
Old Apr 13, 2010 | 06:40 PM
lilpp's Avatar
i pm'd you dude
-lilpp
Old Apr 13, 2010 | 07:05 PM
cgerlecz's Avatar
go home man lol...... CAN SOME ONE HELP ME FOR REAL???
Old Apr 13, 2010 | 07:27 PM
Are you sure that the fuel pressure is actually dropping when you hit 5800 rpms?
Old Apr 13, 2010 | 07:38 PM
cgerlecz's Avatar
To be honest i really dont know but it feels like its hitting a rev limiter
it does it at 5800 but thats not my redline
Old Apr 13, 2010 | 08:27 PM
Mikebike125's Avatar
maybe it is your rev limiter... 5800 is pretty high.
Old Apr 13, 2010 | 08:44 PM
hondadude's Avatar
Could you jumper the Blue 2 pin connector behind the glove box and check for flash codes?
Also how are the basic things; plug wires, plugs, dist rotor.
Also be sure the spark shield disc under the rotor is still there.
Old Apr 13, 2010 | 09:26 PM
cgerlecz's Avatar
um no i havent checked for codes n i think the spark plugs n wires could use replacing cause i bought it in febuary at a small car lot but i think mikebike might be right cause i dont have the stock gauges in my car its automatic gauges in a manual car so im not sure if the manuals have a lower redline or what but i think i might have got scammed cause i have a vtec vavle cover but i havent hit vtec at all atleast not from what i could tell it just doesnt seem like it has all its original parts it seems like i has other parts from other parted accords i think maybe the guy that sold me it just put a vtec vavle cover to trick me but im not sure i just dunno how to go about fixing it if it is a problem
Old Apr 13, 2010 | 09:45 PM
The spark plugs are on the opposite side of the head, the hold-down screws are in different places.... so you can't just swap valve covers.
