-   -   fuel cut (https://www.hondaaccordforum.com/forum/general-tech-help-7/fuel-cut-31888/)
cgerlecz Apr 13, 2010 06:12 PM
fuel cut
i have a 1995 honda accord ex with a 4 cylinder 2.2 vtec motor and i get a fuel cut at about 5800 rpm what could be causing this?
lilpp Apr 13, 2010 06:25 PM
your car is a 1995 correct?
-lilpp
lilpp Apr 13, 2010 06:40 PM
i pm'd you dude
-lilpp
cgerlecz Apr 13, 2010 07:05 PM
go home man lol...... CAN SOME ONE HELP ME FOR REAL???
PAhonda Apr 13, 2010 07:27 PM
Are you sure that the fuel pressure is actually dropping when you hit 5800 rpms?
cgerlecz Apr 13, 2010 07:38 PM
To be honest i really dont know but it feels like its hitting a rev limiter
it does it at 5800 but thats not my redline
Mikebike125 Apr 13, 2010 08:27 PM
maybe it is your rev limiter... 5800 is pretty high.
hondadude Apr 13, 2010 08:44 PM
Could you jumper the Blue 2 pin connector behind the glove box and check for flash codes?
Also how are the basic things; plug wires, plugs, dist rotor.
Also be sure the spark shield disc under the rotor is still there.
cgerlecz Apr 13, 2010 09:26 PM
um no i havent checked for codes n i think the spark plugs n wires could use replacing cause i bought it in febuary at a small car lot but i think mikebike might be right cause i dont have the stock gauges in my car its automatic gauges in a manual car so im not sure if the manuals have a lower redline or what but i think i might have got scammed cause i have a vtec vavle cover but i havent hit vtec at all atleast not from what i could tell it just doesnt seem like it has all its original parts it seems like i has other parts from other parted accords i think maybe the guy that sold me it just put a vtec vavle cover to trick me but im not sure i just dunno how to go about fixing it if it is a problem
JimBlake Apr 13, 2010 09:45 PM
The spark plugs are on the opposite side of the head, the hold-down screws are in different places.... so you can't just swap valve covers.
http://www.hondaautomotiveparts.com/...3sv401_e09.png
