fuel injector cleaner
hey guys i was just wondering what would be the best injector cleaner for my 95 accord lx. im getting around 20 mpg and i would just assume i have some build up in there. air filter is clean so im working on the injectors now. thanks
I like Chevron Techron, but probably there's other good ones too. Lots of people like SeaFoam.
How's the other tune-up stuff like spark plugs & wires? What about dragging brakes? |
I sent you a PM and hope it helps you.
I have been happy with Chevron's complete fuel system cleaner. But some of my friends swear by Redline's, I might give it a try next time.
FREE Injector clean;
Rev the engine to 5k rpm, pinch off the vacuum line at the FPR, let the engine go back to idle. after 5-10 seconds unpinch the vacum line. This blasts gasoline thru the injectors at high pressure during a slow injector pulse. You might trip an O2 sensor code |
BG44K. The strongest thing out there as far as injector cleaners.
bg 44k ,, you can get jut a bottle to add to the gas tank or you can get the kit ( 3 pieces) where you hook it up to a vacc source and run the engine ( 1500-200 rpm ) till can is empty,, also included is the bg 44k to add to tank and a sprayer where you can clean the throttle plate as well..
been using it for years ,, does a great job |
