Fuel neck replacement on 1990
Hi all
I have a 90, 131k on it. The fuel neck is totally rusted, all the way from the opening to the joint into the tank. I just noticed its dripping a bit of fuel onto the ground when I put gas into it. Rock auto has the replacement (the whole neck and I guess the release or exhaust line for the tank) for 40 bucks. Has anyone done this before? From what I've seen you can just pull the neck off and put the new one on. Is that the case? Or do I need to drain the tank and take other precautions? Thanks for your help! |
As long as the level is lower than the install then you are good
Originally Posted by Seanjordan20
(Post 384010)
On my 92 Geo Prizm (Corolla clone) I replaced the filler neck at about the same level (1/4 tank). |
Thanks for the advice. Would you drive or don't drive while waiting for the part to arrive?
(And everything I see online seems to indicate you can replace the neck without dropping the tank. Does that line up with your alls experience?) |
You've been driving it thus far so if you need to then it shouldn't be a problem. You are correct you do not need to drop the tank unless you want to clean it.
Originally Posted by hlockquiok
(Post 384030)
finally got around to this today and the clamps holding the hoses (running out of the fuel tank) onto the fuel neck are so rusted i wasn't able to get them off and i'm wondering if i'm going to be able to get the hoses off the neck. any one have any suggestions for how to remove the clips and then get the hose off the neck without sparking anything? i'm trying to avoid a situation where i get the whole neck off only to f** up the hoses some how and end up with a bigger problem.
I would cut the clamps off with some plier cutters or if you have a small Dremel and use a pick or flat head screwdriver to separate the hose from the pipe. Buy new clamps and put them on during install.
(Post 384333)
I would cut the clamps off with some plier cutters to cut the clamps or if you have a small Dremel and use a pick of flat head screwdriver to separate it from the pipe. Buy new clamps and put them on during install.
What I wrote made no sense. Made an edit. Typing on the phone sucks. Lol
