fuel pump replacement
Old Sep 4, 2008 | 10:47 AM
tobor
Default fuel pump replacement
is there an access cover on the 1993 accord ex so i can replace the fuel pump with out having to drop the fuel tank?
Old Sep 6, 2008 | 07:25 AM
Default RE: fuel pump replacement
Hello tobor..I moved you over here so that your question can get answered..please try to read the forum rules , so that you post in the correct forums..
[IMG]local://upfiles/22/5063E67DE8ED4CBF9028FEF8860CCF2B.jpg[/IMG]
Old Sep 6, 2008 | 09:22 AM
ladd's Avatar
Not sure on the 93 so hopefully someone else will pipe in. You will have an access port in the very front of the trunk. On the 94-97 it only accesses the fuel sending unit and you have to drop the tank to replace the fuel pump. It is likely the same on yours.
Old Sep 6, 2008 | 10:10 AM
For the 90 Accord (likely same for 93), the first step in fuel pump replacement is "remove the fuel tank". Sorry.
If you can search my posts, I described my experience w/ 94 EX fuel pump replacement not too long ago.
Best to run fuel down as much as possible. I found draining the tank to be messy and tedious, and I was on dead empty.
Old Sep 8, 2008 | 01:37 PM
jcocker03's Avatar
can u access the fuel pump by pulling out the back seat? my old camrys were like that
TexasHonda
Nov 16, 2014 01:22 PM
rockhoundrob
Apr 11, 2014 11:41 AM
Westjoe64
Oct 15, 2012 12:11 PM
kissbally78
Jan 18, 2009 07:14 PM
tobor
Sep 4, 2008 05:46 PM
