Fuel Rail Pressure Tester Adapter Request
So this is a request for a write up or some advice on how I could rig something, maybe a schrader valve up to my fuel line so I can easily do fuel pressure tests.
Or I know that some 5th gen accords have the test point. Which ones are they? My 97 doesnt have one but I wonder if I can swap the fuel rail for one that does. And if so, is that point a standard size or is it still the metric size that is almost impossible to find unless its an expensive kit? |
On the 95 EX there is a "port" on the rail....now the adapters and fitting sizes are going to be fun:)
Ok. so its the 95 that has it... But now the question is, how fun will the adapters be? I'm just looking for a more permanent and longterm simple solution so i dont have to get the $150 tester kit.
Is there a schrader valve I could weld or thread on a drilled hole on there thats a standard thread for the cheaper tester kits? |
| All times are GMT -5. The time now is 10:23 AM. |
