Fuse Box Diagram for '94 Accord
My girlfriend lost the owners manual to our 94 Accord EX.....does any have a picture of the Fuse Box Diagram...I need to pull the fuse to the radio antena.
RE: Fuse Box Diagram for '94 Accord
There should be a fuse diagram on or inside all of the covers for the fuse boxes.
I bet here antenna is grinding? If you can't locate the fuse, just unplug the antenna motor. It's easy to access, you just need to pull out the trim piece covering it in the trunk. |
ORIGINAL: finch13 There should be a fuse diagram on or inside all of the covers for the fuse boxes. I bet here antenna is grinding? If you can't locate the fuse, just unplug the antenna motor. It's easy to access, you just need to pull out the trim piece covering it in the trunk. |
ORIGINAL: maineduckhunter its not on the one under the hood, but I haven't found the box in the car yet |
ORIGINAL: finch13 ORIGINAL: maineduckhunter its not on the one under the hood, but I haven't found the box in the car yet |
I can show you one in Japanese lol.
I looked through a helms manual and could not find a fuse listed for that. I would just go with finch's fix |
I've seen the inside fuse box on a 94 accord located on the drivers side below the dash near the hood release..
:eek: |
I found the fuse box inside the car, but she lost the cover to that too....so no diagram.....so just took some advice and unplugged the motor to the antenna in the trunk....NO MORE GRINDING!!! Thanks for all your help!!!
