Grinding/ rubbing sound
Hello,
This thing started today. There is metal grinding/rubbing noise coming from the engine area when I step on the gas pedal in the first approximately 10 feet after start, and I can feel the gas pedal vibrates. The sound and vibration don't last long, for a second maybe, then they go away and the car runs fine. This thing happened three times today already, each time within the first couple of feet of the drive. I'm a little bit worried if there's anything wrong in the transmission system. What can be the problem? I have a 07 accoard v6. Truly appreciated. XingK |
Perhaps the exhaust gusset. There are several postings online concerning the very same issue you've described occurring on Nissan... I'm still looking for one that deals with Honda
Just a shot in the dark, but could be related |
When the car is cold, get it in the air - be safe. Start the car and see if there is a heat sheild that has come loose. When cold you should be able to put your hands on the pipes and sheilds without fear of burning you had.
