Head bolt size
Got a couple head bolts rounded.. Not at home right now, at work, and a guy is going to let me borrow something to get it out with. Just need to know what size it is. Think it's a 9/16 but can't remember for sure.
Guarantee its not a 9/16 as nothing on your Honda is standard size. I'm not for certain as this is just off the top of my head but I think they are 14s. Basically everything except for a few oddballs on Hondas are either 8 10 12 14 or 17l
I would get an OEM bolt.
Many aftermarket bolts may not be correct strength. If you get a purposed "head bolt" you should be OK. I also recollect 14mm socket size bolt. Bolt size from manual is 12mm x 1.25mm, so may be larger than 14mm socket size. good luck |
Also what size is the axle nut on the front drive shafts?
Pretty sure its a 26mm. And I am wrong its 36mm.
Front axle spindle nut is a 36mm hex size.
Redbull get the Thumbs Up
2 Attachment(s)
(Post 327163)
went on AZones site and it said 36mm. :D |
x3 on the 36mm.
I think Cam missed the "3" and hit "2"......:)
This from the guy that can't spell :) |
No I just had a judgement lapse, knew it ended in 6, but come to think of it my socket for the axle nut is a big bigger than 26 lol. Thanks for squaring me away guys.
| All times are GMT -5. The time now is 05:02 AM. |
