headlights
I don't know if this is the right place to post this. My question is where can i get bright light bulbs for my 2003 accord? I've tried couple of places and the only thing I found was 55 watts. does anybody know a site where i could purchase brighter light bulbs?
Thank you!! Accord V6 coupe 2003. |
RE: headlights
The brightest non HID light's that I know of are Sylvania Silverstar, they're about $25.00 per bulb but they are BRIGHT find a set of those and you'll be amazed
RE: headlights
I think i saw those in Auto Zone. And tht price sounds right.
RE: headlights
Thank you guys!! Auto Zone had what i was looking for. Sir you are the man!
RE: headlights
Great! Glad we could help out. Are they bright enough for you?
RE: headlights
Yeahi want to know how bright they are. Very much more bright, like high beams, or barely no difference. Cuz i rele like to drive around in my high beams, so if they r bright enough i'll get them.
RE: headlights
Sylvania's Silverstar headlamp bulbs are theFederal Motor Vehicle Safety Standard (FMVSS)mandated 55 watts for low beam and 65 watts for high beam. There are aftermarket solutions available to you, including "off road use only" bulbs that are higher wattage than original equipment (OE). A wiring harness upgrade is necessary for many higher wattage replacements to prevent overload of the headlamp circuit resulting in fire hazard.
Under FMVSS No. 108 Section S7.7 (replaceable light sources), each replaceable light source for headlamps must be designed to conform to the dimensions and electrical specifications for the headlamp source it is intended to replace. The National Highway Traffic Safety Administration (NHTSA) has alsoruled that thedisclaimer "off road use only"has no legal meaningsince the manufacturer, importeror retailercan notcontrol the product's use once it has been sold. Any equipment offered for salethat is covered by FMVSS No. 108 (headlamps, taillamps, side markers, etc.) must comply with the standard. With that said, andafter having several Silverstar headlamps burn out prematurely, Hellaoffers a great aftermarket replacement that is similar in output and color to the Silverstars and they seem to be lasting longer. Advance Auto Parts carries them, and they conform toFMVSS thus they are street legal. |
