headlights
Old Aug 19, 2008 | 02:29 PM
sharansr
Default headlights
my left headlight is not working.
how much would it cost me to get this fixed?
is it an easy process to change the bulb?
could someonesomeone guide me with this.
Old Aug 19, 2008 | 05:07 PM
falkore24's Avatar
Default RE: headlights
Test the plug for power. That's the first thing.
Old Aug 19, 2008 | 05:08 PM
logan's Avatar
ya my left highbeam isnt working and i swapped out the bulb but it still didnt work
Old Aug 19, 2008 | 09:18 PM
Always check for voltage across the two plug pins with a volt meter. If you don't have 12V across the two pins.......either there is no voltage or bad ground.
There is a fuse for the high beam, check that next.
Old Aug 25, 2008 | 01:04 AM
Go buy yourself a headlight at your local AutoZone and they will show you how to put in the bulb..watch them and learn something...$9.95 average price for a headlight bulb...
Old Aug 25, 2008 | 03:49 PM
logan's Avatar
ya checked fuses all good ill test the power
Pilot Mobbin
Jan 30, 2013 07:18 AM
playav
Dec 4, 2005 04:43 PM
hjl47
Oct 24, 2005 10:28 PM
9JordonAccord9
Sep 29, 2005 11:19 PM
sk8misro
Aug 16, 2005 07:58 PM
