Heat shields around catalytic converter
I have a Honda Accord LX 2001 4-cylinder with Manual transmission. It has run 88,500 miles on it. No major parts have been replaced as of now.
I took the car in for a 90,000 mile service to the Honda of Lisle (zip:60532) dealership and I get the feeling that they are beginning to find something or the other each time I go there to report as "need fixing" or "need replacement". This time around, they came up with the following items:
I am not a very handy person but willing to learn quickly, at least enough to make educated decisions. I am also willing to consider taking my car to some other [trustworthy/reliable] service shop if it will help me save money and don't have to compromise on quality. Any tips/pointers are much appreciated!!! Ashwin |
The heat shield is something that you can replace on your own. They typically rust near the bolts and will start rattling. You can also do a temporary repair by putting a big hose clamp around the shield to prevent it from rattling as a temporary fix.
The timing belt is important. Check the maintenance schedule in the owner's manual for the mileage. I can't remember if it was every 90K for the timing belt on the 98-02 accord. |
I am a novice at car repairs but I replaced the heat shields myself. All you need is access to a lift(preferably but you could roll under the car if you wanted to), and a rachet set. The parts cost me like 60 bucks from an online store and installing was self explanatory and a breeze. My bolts and nuts were rusted on though so I ended up using a pneumatic cutting tool to cut the bolts off. Still it wasn't a big deal. Good luck!
Originally Posted by jamesperiera
(Post 283285)
Well, Im not intending to revived this one up but I had my heat shield rattling to the point that it was annoying. It happene that one of the bolts had rust thru so what I did was that i ordered a new thru online store that deal with shield on catalytic converter. Got the old one removed, but have yet to install the new part. I have been running without it now for over a year, with no adverse effects (even during the heat of summer).
There's also heat-shields above the cat, and those are to protect the floorpan of the car. I don't know whether you'd set anything on fire, but maybe blister the paint & promote corrosion.
