Heater Issues
Well now that its getting closer to the winter, i tried turning on the heat and when the fans are going they just flow out cold air, does anyone have any idea about what it could be
RE: Heater Issues
yes.
make sure that Temp Control Dial is set on HOT. otherwise likely cause - Thermostat stuck closed . please be aware that it takes a while for a car to generate heat - you might need to drive about 5 minutes before you ought to get heat out of the heater. |
| All times are GMT -5. The time now is 05:12 AM. |
