Hello every body Im a new member, Need a Little help plz.
i got a problem in my 2007 accord, Headlights problem i turn the high beam on but when i turn it off the headlights still turning on, I have to disconnect the bulb from the engine to turn it off .
from what i can gather from your explaination, the circuit uses a control module and a high and low headlamp relay. i'd suspect a relay sticking on.
thanks for your help.
Help with installing new HID kit
Just installed new Bosch hid xenon on my 2007 accord with low beam lamps, The problem is when i turn the low beam on the fuses of low beam go down.
i checked up the hid kid with another car and its working fine but on my accord when i turn the headlights on the low beam fuses just damage.i changed the fuses but the problem still exist. note:when i remove the new HID and return the factory one the problem is gone. |
I've merged these together and as such they may not be "in order"....Dr responded without seeing the next post.....
