Hello ..new and need help
Have a 94 accord sedan ex nd its giving me problem when starting it wont turn over just sputters nd turns off replaced starter nd battery it will work after about 3-4 trys while steppin on the gas for it to start any suggestion to what the problem is. I dont know much about cars
Hi , I'm moving this to correct thread :)
Originally Posted by justing920
(Post 327399)
Terms can be confusing.
If you turn the key to start - does the starter spin the engine over but it won't "start and run" on its own? Or, you turn the key to start and nothing happens - stater does not spin the motor? We are willing to help, just need to understand the issue. Also - does the CEL light come on when the car is running? And, are the tune up items (cap, rotor, plugs, check wires) up to date? |
(Post 327484)
If you turn the key to start - does the starter spin the engine over but it won't "start and run" on its own? Or, you turn the key to start and nothing happens - stater does not spin the motor? We are willing to help, just need to understand the issue. Also - does the CEL light come on when the car is running? And, are the tune up items (cap, rotor, plugs, check wires) up to date? Nd etc. |
(Post 327502)
Yes the starter runs and spins but it wont start on its own i have to step on the gas while turning the key to get it to start nd. Im not sure bout that i dont know much about the maitnence schedule of the car just the oil changes
Nd etc. |
If you are unsure of the last tune up then I would plan on that - they wear out.
Get the code - at the top of this section there is a sticky - "Common DIY and Info Threads". In there you will see how to get the codes on you OBD-I car. Once you have the code(s) let us know what it is. |
(Post 327552)
There is a service connetor under/behind the glove box....a blue two pin connector. Jump it with a piece of wire or paperclip and turn the key to on and start counting the flashes from the CEL - D4 - ABS.
(Post 328157)
Sorry but your post is a bit confusing.
For the connector there are several pic's floating around: 94 accord service connector - Google Search |
