Help!!!!
Old Mar 7, 2011 | 10:42 AM
cnapo8's Avatar
Default Help!!!!
ok so this past weekend installed a reman head in my 2003 honda accord (2.4 liter 4 cyl) get everything back together and horray the car starts! so im out for the test drive and all the sudden the car stops running ttry to start it and it wont turn over wondering if there r any special procedures or any ideas u guys might have? also there was a buzzing noise from under the column?? think it might be from the ignition switch?? thinking maybe fuel pump relay?? any help would be appreciated.
Old Mar 7, 2011 | 07:39 PM
Double check all of the grounds. Then have the battery tested.
If the starter is not turning over the engine you are loosing power or ground somewhere. I betting the buzzing is a relay not getting the proper signal...if it was a bad fuel pump relay the starter should still be turning the engine over.
Old Mar 7, 2011 | 09:02 PM
cnapo8's Avatar
Thanks for the reply, tracked down all the grounds and tested the fuel pump relay all were good? The buzzing noise is coming from the steering column right by where the key goes?? Not sure what this piece is called? Its a black box right above where the ignition switch (where the key goes), not really sure where to go from here any help greatly appreciated.
Old Mar 7, 2011 | 09:04 PM
cnapo8's Avatar
By the way brand new battery, thats what staryed this whole thing.
Old Mar 7, 2011 | 09:06 PM
cnapo8's Avatar
Sorry, engine turns over wont start, sorry for any confusion.
Old Mar 8, 2011 | 10:24 AM
cnapo8's Avatar
got the car to run for 40 minutes then on the drive home, shut down like lack of power or something. kicked code p0685, also heard a buzzing coming from the steering column??? any help greatly appreciated.
Old Mar 8, 2011 | 11:45 AM
EXV6NIGHTHAWK's Avatar
Sounds like the electrical part of the ignition switch (not the key cylinder part) is going out.
Old Mar 11, 2011 | 03:58 PM
cnapo8's Avatar
figure id put a follow up, after a few hours of messing with every wire under the hood and dash, the car has been running for about 80 miles, no check engine lights, no nothing...kinda good i guess but still bothers me that couldnt definitivly find something wrong? oh well guess maybe i just lucked out. what part of the ignition switch? what color plug was it the green or the white those were the only two plugs i saw going into the ignition? and the buzzing noise was coming from the steering wheel locking mechanism?? thanks again for all ur help.
Old Mar 11, 2011 | 05:11 PM
P0685 is ECM/PCM Power Control Circuit Malfunction.
I would inspect all ends of both battery cables. I would clean each end with a wire brush and tighten them back down.
I had a problem when I installed a new battery on my 95 and tightened the battery terminals using a boxed end wrench. The connector was loose enough where the cable could lose contact with the batter post. I used a deep 10mm socket and got the bolt to tighten in a few more turns.
brandon0409
Feb 15, 2014 06:36 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
joshk5145
Mar 9, 2008 09:00 PM
