HELP!!!!!
Ok I need some serious help here....I have a 98 accord Ex 2 door V6....here is my problem...about 3 weeks ago my passenger side window stopped working...i mean nothing no clicking no trying to move just dead....so i thought window motors died i just need to replace it....got the new motor hookd it up the the switch and nothing....tested the voltage out of the switch and we were getting power but when it was pushed down or up it was still giving power from both sides...not cutting one side off so that the circuit was reversed...so we hot wired the window motor just to see if it would work and it did(the old motor). So we figured a switch. We hooked everything back up like we had it before and low and behold the window started to work...but then came the other problems. When we turned the key to on where gauges and everything comes on the gauges would spike almost like they were resetting...the key less entry stopped working....the trip milages reader resets everytime...the a/c resets itself...the clock dims in and out...when the key is turned off and the parking/headlight are on they turn off with the key not stay on like they should...there is not theater lighting...the dome light doesnt come on when the door is open...and it is set to door in the center of the dome light...and the power door locks will not working unless the key is turned to the on position....so i checked all the fuses under the hood, drivers box, and passengers box and they al have one thing in common...the prongs on the fuses are scorched...not burned out...the fuse is in good shape and still functioning but there is obviously something wrong....so if anybody has any ideas or has had a similar problem please help me and let me know something...thanks keaton
RE: HELP!!!!!
how did you HOT WIRE the window motor ??
did you by any chance HOT WIRED the wrong wire at first ?? |
| All times are GMT -5. The time now is 10:31 AM. |
