Help!!!
i have a 94 accord automatic. transmission problem. checked code, it is
#8. Faulty wiring / short, tranmission **** contrl soelnoid B. Replaced solenoids, still getting same code. What to do now? |
I seen that code before on a different car, and it was the wiring itself. What I would do is I would check the wire that goes to the solenoid. Check it to make sure that its even connected and that its not cut or open to where you can see the wires or grounded somewhere.
Are there any other check engine codes besides that one? |
Be sure to check the connector as well, I've seen where the pins inside the connector get dirty and will not make good contact.
